45 Loader Bucket Return Spring Question
AlbertoV05
03-09-2003 14:27:11
I just bought a 45 Loader for my Model 60. The entire unit is REAL nice - everything is straight and NO cracks : )
It does not have the bucket return spring assembly so I need to locate one (hopefully not to big of a chore with a fist full of salvage yard phone numbers)?
Does anyone have a picture showing which side this assembly goes on and where exactly that spring connects to the bucket? Also, if you have a pic showing how the hydraulic lines are run that would be great! I'm hooking it up to the breakaway quick-disconnects on the left side of the rear axle.
I've got the Operators and Parts Manuals, but they don't clearly show where the spring hooks up or where the hydraulic lines are run.
Thanks in advance!
Al in Iowa
john b.
03-11-2003 17:04:14
 Re: 45 Loader Bucket Return Spring Question in reply to AlbertoV05, 03-09-2003 14:27:11
There is a spring that goes on the bucket latch.
this is the only spring I know about. I believe it goes on the right side of the latch. I bought these springs from my local John Deere dealer.
I have a 45 loader that I restored 2 years ago.
JD
03-09-2003 17:50:45
I don't have a return spring on my 45 loader. I see lots of 45 loaders. None of them have it. The return spring is in the part catalog. That's all i know about it.
AlbertoV05
03-09-2003 18:31:32
 Re: Re: 45 Loader Bucket Return Spring Question in reply to JD, 03-09-2003 17:50:45
JD,
Thanks for the info. I see the parts are in the catalog, but according to Deere's "JDPARTS" website they are no longer available (no surprise)!
By the way, how did you route your hydraulic lines? What model tractor is yours mounted on?
Thanks!
Al in Iowa
jdjaack
03-09-2003 19:04:32
 Re: Re: Re: 45 Loader Bucket Return Spring Question in reply to AlbertoV05, 03-09-2003 18:31:32
We have a 45 loader mounted on a 60.
Hoses come to back of the tractor and are t'eed together, equal distance, where they plug into power-trol. It doesn't have a return spring on it.
If you dump something, the bucket usually comes back and locks. Other wise just lower loader and backup. Other 45 loader we have has hydraulic dump.
