49'JD G Sliding gear shaft drive
Gary
03-08-2003 17:31:39
My problem is that I checked my sliding gear shaft, Its loose you can move it around inside the sliding gear, Would it be a good bet to say the bearing is shot, And what will it take to fix?
Thanks for any help!
Clooney
03-08-2003 17:39:41
 Re: 49'JD G Sliding gear shaft drive in reply to Gary, 03-08-2003 17:31:39
Gary, depending on the amount of movement, & the direction of the movement, it could have worn bearings, or the input shaft bearing(s) could be worn, or the case bore could be worn, or all of the above.
~If you're lucky you might be able to slide the shaft out the L/H side of the case after removing the L/H bearing snap ring. ~The problem is; if the bearings are worn or pitted on that sliding gear shaft all the rest of the trans bearing probably are the same way...
Gary
03-08-2003 18:09:32
 Re: Re: 49'JD G Sliding gear shaft drive in reply to Clooney, 03-08-2003 17:39:41
Thanks Clooney, There is alot of movement, The shaft wallers around the entire inside of the sliding gear. The reason I checked it was I could here a knocking sound coming from the transmission area.
Thanks, Gary
