3 pt. hitch for an A
Family Traditio
03-08-2003 12:12:59
found a man who has a 3 pt. hitch on a G and was wondering if this hitch will fit a 51 A?
DP
03-08-2003 15:26:53
 Re: 3 pt. hitch for an A in reply to Family Tradition, 03-08-2003 12:12:59
You will be alright if your A is new enough to have the 46 and later drawbar, or has been changed over to that. The after market 3 points mostly just bolt to the axles, so they should work. As John T said, you should have the Power-Trol box for it to work right. Good luck to you. Don
John T
03-08-2003 12:48:44
Hey Tradition, if thats a regular run of the mill JD brand 3 pt hitch like an 801, or even another brand after market that uses the rocker arm shafts to lift and the arms pivot down there off the drawbar mount, it should fit that A if it fit on a G. Remember, the Power Trol (I assume the A has that) has to have the right plugs to divert the hydraulic pressure to lift the rocker shaft as opposed to operate a remote hydraulic cylinder. Some hitches have that unGodly looking top link assembly that mounts on the rear axles and serves as a Top Link for the JD plows etc., you can get by without that if you have another one properly rigged and mounted. God Bless the USA Ol John T Nordhoff
