JD GM
bill
03-07-2003 19:20:44
Does anyone know what years the GM was made and possibly the serial number break; thanks.
Stan - Florida
03-07-2003 20:05:03
 Re: JD GM in reply to bill, 03-07-2003 19:20:44
JD70Jim is right about the serial number breaks. Also, these changes were made in mid-year, so there are both unstyled and styled 1942 models and both GM and late styled G 1947 models.
Stan
Will P
03-07-2003 20:41:16
 Re: Re: JD GM in reply to Stan - Florida, 03-07-2003 20:05:03
Just a little note. There are no 44 GM's
But other wise I agree with you.
Will P
Stan - Florida
03-08-2003 03:50:14
 Re: Re: Re: JD GM in reply to Will P, 03-07-2003 20:41:16
Will,
You're absolutely right - my information showed that and I forgot to mention it.
Good call!!
Stan
JD70Jim
03-07-2003 19:35:40
Go to the sidebar to the left.
Click on "Serial Numbers"
The list shows the "styled G" without identifing GM ans G, but the serial break for GM and the u/s G was at 12,999/13,000. The G returned in 1947 @ sn 23,000.
bill
03-07-2003 20:00:53
 Re: Re: JD GM in reply to JD70Jim, 03-07-2003 19:35:40
were all Gs from serial 13000 to 23000 known as GMs; I was told those made right after WW II , in early 46 until late 47 were the GMs thanks, bill
JD70Jim
03-08-2003 07:12:48
 Re: Re: Re: JD GM in reply to bill, 03-07-2003 20:00:53
In 1941, John deere was about to introduce a STYLED "G", to replace the unstyled version. It would COST more to produce than the old version.
However, WAR with Japan and Germany had just broken out, and the WARTIME PRODUCTION BOARD would not permit John deere a price increase for the new tractor if the tractor were to be called a "G", hence, John Deere renamed it the "GM" or "G Modern", and they got their price increase.
Unfortunately, the GM wasn't produced right away because Deere could build TWO "B" tractors for the amount of materials used to build ONE GM. After only a small production run, the GM was suspended until 1944 when materials to build farm tractors were made available.
After the was, when John Deere restyled the GM again, @ sn 23,000 (when they gave it the battery box seat) and since the was was over, it was simply renamed "G" again.
bill
03-08-2003 10:01:51
 Re: Re: Re: Re: JD GM in reply to JD70Jim, 03-08-2003 07:12:48
A big thanks for your time;; bill
