Tom, if it doesn't kick back when hand starting & runs good when running, the timing is close enough for it to start good. ~That might be a rather hard problem to figure out & will take trying different things to eliminate them one by one. ~Start with the obvious; Does the mag snap when the flywheel is turned over real slow?--- [if not that's your problem]. ~If the mag snaps, take an old [known good] spark plug & open the gap to 3/16" [use a 3/16" drill bit as a gap gage]. Install that plug in one plug wire at a time & lay on the block, then crank the engine by hand [you need a blue spark that jumps that 3/16 gap multiple times in a row, not just once]. ~If all OK so far, try different choke settings [in some cases too much choke won't let any air in with the fuel & it won't get to the cylinders]. Just as a "see what happens" try cranking with full choke 1st turn, 7/8 choke 2nd turn, 3/4 choke 3rd turn, 1/2 choke 4th turn. If no fire go back to 3/4 choke for a turn or 2, then no choke & wide open throttle for the next few. ~Try different throttle settings, my H likes as little throttle as possible & still run after starting [just slightly off the carb throttle lever stop pin]. ~Make sure the carb choke plate is closing ALL the way & not bent. Make sure the choke plate trap door is there, the spring is functional, & the trap door is opening towards the carb. ~Try opening the carb load & idle needles 1-2 more turns each [just for starting]. ~Make sure you have the correct solid metal center plug wires [not automobile TVRS carbon resistor wires] ~Try opening the spark plug gap to .035" [that helps on my personal H] ~Give it a cold hand cranking compression test, leave one spark plug in & test the hand cranking compression on the other, then do the other side. See what the compression is with the choke on & only after one time over with the flywheel [starting compression]. ~If you already haven't done so, install NEW gasoline [regular, no premium] & with no alcohol content if possible. ~Make sure the throttle plate is centered in the cab bore & isn't worn on the ends [that is a big factor in low RPM cranking starting]. ~When you stop the engine, shut the fuel off & run the carb dry, or open the carb drain valve after shut down. ~If you have exhausted all of the above [& yourself] it's time to try substituting a different mag, & trying a different carb
