John Deere D head gasket con rod bolts
Frank
03-07-2003 12:28:03
Putting JD D back together. Connecting rod torque is 100 lb . When tightening nuts to line up with slots for cotter key should you over tighten or under. Also when putting on head gasket should it be dry or use shelac or ?
AlbertoV05
03-07-2003 13:31:07
 Re: John Deere D head gasket con rod bolts in reply to Frank , 03-07-2003 12:28:03
third party image
Frank,
While my 60 is no Model D I can't imagine the correct procedure of installing nuts on rod bolts would be any different?
My 60 Manual says to tighten them to 100 ft/lbs. If the castellations do not line up tighten to the next castellation.
As for the head gasket dressing, I searched some the archive posts on some of the well-liked dressings and Permatex #3D comes up quite a bit. It's Permatex #80017 or 19 (depending on size of bottle) and is called "Aviation Form-A-Gasket". If I did it right I've attached a link that will take you right to Permatex's webpage for this product.
Good luck!
Al in Iowa
cheg
03-07-2003 13:29:24
Hey Frank,
I had to switch my connecting rod nuts around in order to get the slots to line up with the cotter pins. It took a couple tries, but I found the right combination.
