JD 111 rearend fluid ?
Jonathan
03-07-2003 11:52:16
third party image
I have a JD 111 its has the factory peerless gearbox/rearend I was wondering if their was a way to service the fluid thats inside it. Like being able to change or fill it etc...
Bob-Wyo
03-07-2003 14:15:52
 Re: JD 111 rearend fluid ? in reply to Jonathan, 03-07-2003 11:52:16
Hi Johnathan, those rear ends are packed in grease, and yes it is a good idea to take them apart and wash the parts, check bushings, axle seals and repack them with a very good quality of grease. Also you ought to check the drive chain, if it is pretty loose,(slack)now would be a good time to change it. Most time the jerking is in the wheel/axle keyways.
Hope this is of some help to you.
Bob
mark
03-07-2003 12:36:48
no , there is a gun like grease in that transmission. The weak point is the bearings that the axles ride on. They are bronze. I don't remember if there is a hole on top of the axle housing to put some oil.
