510 Backhoe Transmission problem
BH
03-07-2003 08:23:15
JD 510 backhoe loader ran fine but now will move forward or back. Acts like it will not go into gear. Hydraulics work fine.
No grinding noise. Nothing. It Just wont move.
Where do I start? Is there any luck that it is just a plugged screen or will I have to break this thing in half?
Thanks,
BH
oscar
03-08-2003 12:37:34
 Re: 510 Backhoe Transmission problem in reply to BH, 03-07-2003 08:23:15
jonathan i had this problem on a 410 it turned out to be a siezed planetary in the shuttle pack and you do have to split the machine for access but only have to move engie forward and you can get at it but lets hope its what the others say
Jonathan
03-08-2003 05:25:15
A 510 huh ??? $$$$$$$$$$$$ .....When you shift the transmission ...1 thru 8 , does it make any sounds like its working inside ??? engine lugging slightly etc ?? There is a tow disconnect lever on the rear right top of the transmission...right in front of the axle housing...It disconnects the transmission so the backhoe can be towed...maybe that got dislodged....hopefully !! Its sometimes hard to locate due to the location and there is usually 4 inches of crap on top of it....
cannonball
03-07-2003 09:48:40
make sure that the linkage is not lose under the tractor ...it works from one side to the other ..make sure that the linkage is working the valve that shifts the reverser...have nice day may god bless
