420 slant wheel universal joint
xwrench
01-05-2004 16:54:17
I am looking for any and all suggestions for the replacement of the steering shaft universal on the slant wheel 420s. I am looking for any alternatives other than the $500.00 that John deere wants for a new one. Thank You
Sincerely
Marty Hall
Henry J
01-07-2004 09:25:21
 Re: 420 slant wheel universal joint in reply to xwrench, 01-05-2004 16:54:17
xwrench
I am snowbirding right now. Can't find my photo gallery on the library puter. The Sears 1/2 U Joint that Wayne talked about worked good. I will be back at the barn in about 6 weeks. If you are still interested in a picture of mine email me.
Steve
01-07-2004 07:21:34
I've rebuilt several of the 420 steering joints for a lot less than a new one. I can't fix the splines but I can do the rest. Let me know if you're interested.
Steve
Ray
01-05-2004 19:32:20
One just sold on ebay for $43.I've used a universal from a truck pto shaft before,just
weld on the splined end and the steering wheel
end.
TPat
01-05-2004 17:19:52
Mr. Hall, I rebuilt one using hot water pvc and a bench grinder. It took a little while to "machine/grind down to fit where the original nylon bushing were- but it works well on mine. The joint was not worn and the homemade bushings made it tight. If and when that fails, I am going to have a machinst to help me simply put a later model universal joint in it. Good luck !!
Wayne in Tn.
01-06-2004 08:55:23
 Re: Re: 420 slant wheel universal joint in reply to TPat, 01-05-2004 17:19:52
Yep, ain't that a little ridiculous for the price? Also there are two different types of those joints. I believe the 430 went to one that you can't put bushings in. Anyway maybe Henry J. will post a photo of his remedy. He used a 1/2 inch drive wiggle joint from a set of wrenches. He had the ends welded to it and says it works fine.
