JD round balers
HA in Oh
03-06-2003 02:06:48
I'm looking for a baler w/net wrap and to do some haylage with. I'm goneing to look at 435's, 535's 466's, and 566's. Is one of this modles better then the other? What should I look for as weak and woren items? Thanks for any help.
Jim from Colo
07-12-2004 08:45:17
 Re: JD round balers in reply to HA in Oh, 03-06-2003 02:06:48
I have a 535 with net wrap. It has been failing to completly cover the bale with the wrap. Sometimes only one side, sometimes both. I have tried overloading the ends, middle etc... to no avail. At times it lacks covering 12 inches on one side or the other. Where I live no one knows about these balers including the JD dealers. When I rake two windrows together it does fine, but I dont want to rake and shatter the hay if I dont have to. I would REALLY appp. some advice on how to fix this problem.
Gpower
03-06-2003 13:35:05
The 566 would be a good choice as well. The pickup and starter roll system is way better than the 535, even though you can still encounter problems. 566 does not have the hydraulic tying system like the 30, 35 series do, as the 6 series and now 7 series are all electric. This make adjusting tying options, speed, spacing and end adjustments all done from inside the cab thru the electronic monitor, and really takes about 30 seconds to do once you have the system figured out. Sure there is more electronics on the 6 series, and some people do not like that idea, but the 6 series have come a long ways.
Now the fun part is the net wrap feature. The most common problem with this feature is proper adjustment of the gaurds, rollers and linkage on the wrap system. Also it makes a difference on the type of ground cover you have. I can not emphasize enough the importnace of using the talc lubricant, (Just plain ole baby powder) that Deere recomends. This will defeat the static electricity and allow the net to feed properly through the rollers and not "stick" and jamb up. You can string tye a round bale in about a minute with a 5 foot baler, and 7 seconds with the wrap. You can get up to 50 more bales per day on average just using the wrap, some cases over 100. Not uncommon tohear of a guy putting up 325 rolls in a day. The new 7 series balers are really sweet on the feedng and drive system for the net wrap. Basically trouble free. Much better than the 6 series, but you have to pay for that new baler. You can make a 6 series run all day long with no problem, the key is knowing how the system works, or having a good tech to help you out. Whew, that was windy, hope this helps, Good Luck
Gpower
David from Kansas
03-06-2003 07:12:47
HA. The 535 is a darn good baler and will cost considerable less than 566. Both make a five foot wide bale, whereas the 435 and 466 only make a four foot bale. We have been using 530 and 535 balers for the past 10-15 years, had used Heston prior to that but the JD's seem to make a better bale and are more trouble-free. Things to look for: worn out bearings on the rollers, belts, and the hay pickup, which usually shows wear before the rest of the baler. Also, look at the main drive chain and spockets on the left side of the baler. You can often tell how much a baler has been used by the paint on the pickup. If it is all shiny with little paint, it probably has baled a lot of hay; if the paint looks good, probably lightly used. One weak point on the 535 was the hitch assembly. Look for cracks and welds. They usually broke just behind the drawbar hook-up. Hope this helps and good luck. If you have any other questions I would be glad to help. David
HA in Oh
03-09-2003 05:20:35
 Re: Re: JD round balers in reply to David from Kansas, 03-06-2003 07:12:47
I looked at a 466 last friday dealer hasn't picked up yet so he took me to the farm to look at it. I talked to the owner, he said that he had problems when he first got it with the big roles of net. He said he used the powder and done everything Deere said to do, he switched to the small roles of neting and had no more problems. The big roles had to much drag and would stretch then tear. This baler had a lot of wear on the drive sprockets and had baled close to 7000 bales. I think I'll keep looking.
