Hydraulics John Deere 2010
hydraulic-less
03-05-2003 19:09:25
My hydraulics quit working on my John Deere 2010. I check the fluid and it was low. I added fluid hoping it would start working again but it hasn't yet. In the past it has quit due to low fluid and when I added fluid it would start working again. Has my luck ran out? Any suggestions/recommendations other that burning?
Hoosier
03-08-2003 18:10:05
 Re: Hydraulics John Deere 2010 in reply to hydraulic-less, 03-05-2003 19:09:25
Check hyd filter. Was a couple updates-last one was a brass filter
Bob Clark
03-05-2003 19:55:36
Under the belly, just in front of the axle, is an access hole and the hydraulic pump is in there. You can remove it and check the o-rings. I recall that there is a suction screen there also that you can pull out. We had a 2010 untility with a 46a loader. When we blew the bucket cylinder packings we would have to clean the screen a couple of times in the next month or so. I might be more serious but I'd start there.
