Gear shift knobs
Darrell
03-05-2003 14:17:33
I have seen on some old JD's a knob on the shifter. Are these stock ? If a simple push on, where do i get one,If threaded on, HOW ?
F-I-T
03-05-2003 14:45:31
 Re: gear shift knobs in reply to Darrell, 03-05-2003 14:17:33
third party image
Darrell:
As I recall, the 'H' and 'G' had knobs, but the 'B' and 'A' did not. I think they became standard equipment on the numbered series. The shifter shaft has a pilot that was threaded to receive the knob.
This diagram shows a '60' shifter.
Frank-in-Tallahassee
70D // 855
Darrell
03-05-2003 14:53:15
 Re: Re: gear shift knobs in reply to F-I-T, 03-05-2003 14:45:31
And mine is a B.But I have seen shifter knobs on B'S
Clooney
03-05-2003 15:04:07
 Re: Re: Re: gear shift knobs in reply to Darrell, 03-05-2003 14:53:15
Darrell, the late B's were subbed to the 50 shift lever & big knob for replacement parts. On some of the late B's the shift parts were changed out to the later interlock shifter parts so the trans didn't jump out of gear, & that usually included the late shift lever & knob..... ..
Denny
03-05-2003 20:04:54
 Re: Re: Re: Re: gear shift knobs in reply to Clooney, 03-05-2003 15:04:07
Clooney, I was wondering if you know where I can get one of those gear shift knobs like the one on the 50-730 tractors. I need one for my 530. Thanks for the help on this and on all the other questions you answer. Denny
Clooney
03-06-2003 02:39:36
 Re: Re: Re: Re: Re: gear shift knobs in reply to Denny, 03-05-2003 20:04:54
Denny, you can try calling your dealer & have them check the dealer network. You will need an AP-17808H knob. If there are none in the system try Greg Stephen [303-688-3151]..... .
