Fly wheel blues
in need of help
03-05-2003 09:37:16
the flywheel on my A keeps comeing lose. is this a regular occurance with the A. and how do i stop it from cmeing off?
thanks to all
03-05-2003 16:12:13
 Re: fly wheel blues in reply to in need of help, 03-05-2003 09:37:16
Chuck W
03-05-2003 12:48:36
the flywheel should wear before the splines. If you've tightened several time, I would try and other flywheel with new John Deere bolts. The wheel should tighten with little torque if proper, however you want to be sure to set to the factory torque. If splines are badly worn on crank then you may need to try to build up or just replace.
F-I-T
03-05-2003 13:24:30
 Re: Re: fly wheel blues in reply to Chuck W, 03-05-2003 12:48:36
Chuck:
If it's worn that bad, he might be able to salvage it by installing a Tap-R-Loc flywheel kit. I have not used one, but those who have tell me that they realy do hold tight !
Frank
thanks
03-05-2003 10:15:48
my nabor says that he has herd of them coming off in the field without worning is this cause the old bolts are just that? thanks i am a new owner so.
Jim Jones
03-05-2003 10:01:24
Check and see if the bolts are streched or not---sounds like they are streching----causing the flywheel to loosen up--.There was a posting a while ago that showed what stretched flywheel bolts look like,not sure if Clooney sent it or not? If bolts are ok---look at the splines on both the crank,and flywheel,make sure they aren't worn, My guess? stretched bolts,it doesn't take much streching to make the flywheel loose.----- ----- --good luck----- --Jim.
F-I-T
03-05-2003 09:59:36
In Need of help:
Are the flywheel splines clean and in good condition ? Same for the flyhweel splines.
Losening can come from bolts not torqued to spec, or the old bolts have stretched, and continue to stretch after you tighten them up. I have found that excess flywheel endplay can also affect the ability to keep the flywheel tight.
Start with clean splines on both the crankshaft and the flywheel, get the endplay set correctly, and use new Grade bolts ( I like fine thread along with tall nuts and hardened washers under the nuts.).
If the splines are in good shape, and clean and bright with no burrs, you should be able to get the flywheel tight and keep it tight.
Frank-in-Tallahassee
70D // 855
havvey
03-05-2003 11:44:44
 Re: Re: fly wheel blues in reply to F-I-T, 03-05-2003 09:59:36
i used to see this more on the late a and 70's the other guys covered it pretty much have seen flywheels waPed or cracked YOU NEED TO GET THIS FIXED AS IT IS DANGEROUS YES IT COULD MEAN A NEW CRANK OR WHEEL AND IT CAN CAUSE ALOT OF DAMAGE TO THE REST OF THE ENGINE PARTS THERE WERE A FEW PEOPLE THAT (BOUGHT THE FARM FROM THIS COMMING OFF)I HAVE SEEN FLYWHEEL COME OF AN A AND LARGE SAWMILL PULLEYS COME OFF SHAFTS SO GET IT FIXED! ALSO CHECK WITH JOHN DEERE THOSE BOLTS ARE NOT RUN OF THE MILL HARDWARE STORE BOLTS AND CHECK THE FLYWHEEL BOLT HOLES FOR WARE GOOD LUCK
