Flat spoke fronts?
Chooch
01-05-2004 13:14:57
My current project is a '29 GP. The only thing unusual about it is that it has "flat" spoke cut-offs on the front which match the rear. The fronts appear to be for the GP as they narrow in the middle of the axle housing like most GP fronts I've seen. Although I try to attend several shows a year, I cannot recall seeing flat spoke fronts on many tractors. Just curious if anyone knows anything about flat spoke fronts?
Duane Larson
01-05-2004 13:30:45
 Re: Flat spoke fronts? in reply to Chooch, 01-05-2004 13:14:57
Chooch,
GP standard's from 200111-208383 (mid '29 model year) used the AC167 wheel, which had flat spokes and the hourglass hub. So, those wheels would have been the source of your cutoff's.
Chooch
01-05-2004 13:38:38
 Re: Re: Flat spoke fronts? in reply to Duane Larson, 01-05-2004 13:30:45
Duane,
Thanks for the info. I could not find them in my parts book. However, my serial number 205xxx does fall within the range you provided.
Duane Larson
01-05-2004 14:37:57
 Re: Re: Re: Flat spoke fronts? in reply to Chooch, 01-05-2004 13:38:38
Chooch,
They are in Repair Catalog 41R (June 1, 1931). They were replaced by AC651R, a round spoke wheel. Your hub wheels have a characteristic F&H shape, while the AD651R have the characteristic JD hub shape.
