Clooney(wireing)
Jack
03-04-2003 07:34:03
I need a diagram for wireing a JD up for 12 volt negative ground with an alternator.Pull on push off switch.Will be using a one wire alternator.Thanks Clooney,Jack(TN).
Clooney
03-04-2003 09:16:42
 Re: Clooney(wireing) in reply to Jack, 03-04-2003 07:34:03
Jack, mag or distributor? What model, type & year Deere? What lights are you running eg, front only, front & rear, none? How many amps output is the alternator? [it should be stamped on the case]. Alternator output isn't completely necessary but would help for wire size.
Jack
03-04-2003 09:31:47
 Re: Re: Clooney(wireing) in reply to Clooney, 03-04-2003 09:16:42
It is a 60 JD w/electronic ignition w/o the factory ignition switch.It will be a GM 40 to 50 volt one wire with no lighting.This 1954 60 is strictly for pulling.Thanks Clooney.
Clooney
03-04-2003 11:28:40
 Re: Re: Re: Clooney(wireing) in reply to Jack, 03-04-2003 09:31:47
Jack, I sent you a full color wire diagram showing wire sizes & attachments for a pos. ground alternator system with a simple ign switch. My work server has been acting up so if you get the E-Mail without the attachment let me know & I will resend if from home..
Clooney--correction--
03-04-2003 14:48:19
 Re: Re: Re: Re: Clooney(wireing) in reply to Clooney, 03-04-2003 11:28:40
Jack, I sent it to you for the correct ground [for negative ground] but wrote it wrong above. Again the diagram is correct....
Jack
03-04-2003 15:01:42
 Re: Re: Re: Re: Re: Clooney(wireing) in reply to Clooney--correction--, 03-04-2003 14:48:19
yeah,I was going to ask you but when I checked my email I seen that you had that right.Thanks again sir,and I think your a fine fella.
