420 throttle lever question?
Wayne in Tn.
03-03-2003 19:45:03
Just purchased a 420T tricycle with the slant steering wheel. Serial number is 126150 The throttle lever is bent or curved downward away from the steering wheel. The tip of the lever is at least 8 inches or more, away from the steering wheel. Is this original or has it been heated and bent this far? I can't tell about the heating, it has a good coat of paint over it. Maybe someone that owns one of these models can tell me if this is correct. Thanks in advance.
Hayman
03-03-2003 22:29:41
 Re: 420 throttle lever question? in reply to Wayne in Tn., 03-03-2003 19:45:03
That does definately sound not right,
Ray
03-03-2003 20:20:58
The last 420'S had different levers than the
earlier ones,that's probably what you got.The
last 330-430 tractors had longer throttle levers than the earlier ones also.
