DLTH 67 QUESTION
Dave in Ohio
03-03-2003 15:46:55
I have a DLTX 67 carburator that has a crack through the threads that hold the float bowl on. The crack is about an inch long. Am I safe to cut a small V, say 1/16" deep, drill a 1/8" hole at the top of the crack to keep it from running and TIG welding this up, file to original dia. and then work out the threads with a thread file ?
Or is there a better or easier way?
steve II JD4000
03-03-2003 18:41:22
 Re: DLTH 67 QUESTION in reply to Dave in Ohio, 03-03-2003 15:46:55
third party image
hey. I know it may be hard part I am't sure where you say crack is at. but I did my carb by brazing it looks much better here see a pic..
Clooney
03-03-2003 17:52:50
Dave, you could try it. I doubt you will have much luck TIG welding that casting. You would need a high nickel rod & it would be hard to repair the threads after that. You might try brazing it, brass holds pretty good on that old casting metal. I guess if it doesn't work out you could always cut the bottom off & install a new bottom thread section. I don't know if anybody is selling a new lower threaded stem. I usually make one on the lathe with a little sleeve sticking out, then counter bore the carb stem & silver solder it in...
dave
03-03-2003 17:38:06
I have a die for the stem threads, and this fall I was told it was the same as spark plug threads-----this is not a fact just a old mechanics knowledge.
Larry806
03-03-2003 19:36:42
 Re: Re: DLTH 67 QUESTION in reply to dave, 03-03-2003 17:38:06
The threads are the same as the plugs in unstyled tractors 7/8 X 18 I've have fixed several like that
