Gear puller size
Jess
03-03-2003 08:30:11
I presently have a gear puller with a 9 inch spread. I am interesting in buying a bigger puller to do service work on on a JD 60 and a JD A. I would like to get by with buying only one more puller. I am looking at two pullers from NAPA--one with a 12 inch spread and one with a 15 inch spread. Can someone tell me if the 12 inch spread puller is big enough for anything I might run into on two cylinder JDs or do I need to go to the 15 inch puller. Also if you know of a vendor other than NAPA that I should check out please advise. Thanks for any information --- I asked this question on the tool forum but that forum does not seem to be nearly as active as this forum.
