Foaming gear oil
Don c
01-05-2004 11:17:39
Just changed oil in trans. and rear end, JD60. Put GL-1 90wt. as thats all I can find in my area. Run it and rechecked it, was very foamy, after it set for a bit was alright, question is thought the straight 90wt. wouldn't foam. Also when I was still working we had some oil at work for a high speed turbine and it started to foam, they had us put a small amount of diesel fuel in it to take care of it and it worked. Should I worry about the foaming or not or would you add a little diesel to it. Thanks, Don c
Clooney
01-05-2004 18:43:06
 Re: Foaming gear oil in reply to Don c, 01-05-2004 11:17:39
Don, that gear oil is probably just cold & thick.. Gear oil will retain air if stirred up with spinning gears when cold & thick. It shouldn't do that after it warms up.. Nothing to worry about as there is no oil pump or small oil pipes..
