830 transfer pump machining
robert
01-05-2004 10:21:37
Finally got to it.Transfer pump pressure only 10-12 psi with shimming ball,Gears seem healthy but notice some wear on end plate.Figure on machining cover plate flat again,and possibly a hair off of body so long that gears spin freely when done up again.Does this sound OK,as I think there is just too much end clearance causing the low pressure problem.The pressure is no higher when I plug the return to tank line.What do I use for end cover sealant.I see old book says shelec,can one still buy that.
Clooney
01-05-2004 13:55:56
 Re: 830 transfer pump machining in reply to robert, 01-05-2004 10:21:37
Robert, on the cover, body & gear end play..
~You could have wear in a lot of areas like gear teeth & shaft wear as well as excessive end play.
~On the cover to gear clearance, it probably has opened up a little but it needs some so the gears don't tear the cover up...
~Use a flat piece of window glass & some 360 or 400 wet & dry sand paper on it.. Put a little soapy water on the paper the stroke the pump body & end cover on the wet & dry [keep changing directions & rotate the cover or pump body while stroking].. Once the cover is flat work on the pump body only.. Keep checking the gear to cover end play & when it gets to around .003"-.004" stop as that is tight enough..
~On the sealer...for years I have used a very thin coat of Loc-Tite 518 & that seemed to work pretty darn good [it's an anaerobic sealer & gasket eliminator].. Lately I have been using a light coat of 2 part urethane clear paint [from a clear coat base coat left over].. Urethane clear is expensive to go out & buy so if you don't have any handy or don't know someone with a little left over you might be better off with something else.. While the 518 holds good & doesn't cause any problems if a little enters the fuel system I thought it might be adding a slight height to the cover so tried the urethane clear coat as that is real thin but dries solid as a rock. So far that has held up good.. But, I'm sure you can still buy gasket shellac if you look around enough..
[email protected]
Hilltopper
01-05-2004 12:39:14
Yes you can still buy it at a parts store. comes in a small bottle with a swab. Once opened it sets up pretty fast.
twopop
01-05-2004 11:48:24
how about using polyurethane varnish
