GP Potato ???
steve
03-02-2003 11:44:46
I found a tractor that the 83 yr old owners dad bought in 1930. The man says it is a potato,but
there is no tag or holes drilled for tag.
What could this tractor be? Thanks.
Ed Green
09-04-2003 00:26:20
 Re: GP Potato ??? in reply to steve, 03-02-2003 11:44:46
i have a 1930 or 29 John deere wide tread narrow front i want to sell. in cali
steve
03-05-2003 15:11:58
the tractor has narrow front,68 inch wheels
side steer, but no tag or holes for tag.
it should be a potato but can not be sure.
the man wants 2500. it looks to be complete,
turns over with compression but dont run.
J Bouchard
03-04-2003 19:41:49
what you may have is a GP P series tractor. There were 203 of these made in the 1930 model year. The serial tag is located at the rear of the maincase just below the shifter. It is a place that was easily damaged so some Model P tractors are without. For potato farming these tractors had a 68 inch rear width which is narrower than a typical GPWT tractor. These are small bore (5 3/4 in.) GP's. In 1931, a special wheel was made to be offset and narrow a regular GPWT to the 68" width. This is a very collectable tractor if it can be identified as a model P series GP.
HAVVEY
03-02-2003 15:44:33
MOST POTATO WENT TO MAINE SOME TO LONG ISL AND A FEW TO TEXAS FROM WHAT I REMEMBER THE AIR CLEANER OR MUFFLER IS OUTSIDE OR OPPISIT THE GP YOU COULD HAVE A GP OR A D MODLE A GOOD BOOK LIKE JOHNNY POPPER WILL HELP IDENTIFY THEM FOR YOU
Paul
03-04-2003 14:20:10
 Re: Re: GP Potato ??? in reply to HAVVEY, 03-02-2003 15:44:33
If you can supply some pictures it would be easier to get help. If you cannot do that, provide a better description, i.e., wide front or narrow, etc. Also get some numbers of the castings. Be sure to include the quill casting numbers.
Paul
03-04-2003 14:20:05
