Tractor ID
arthur
03-01-2003 19:02:55
i bought a john deer industral numbers on the engine are M41TW 174931 the number to the transmision is type 471TW serial no.11584T the only number on the loader is JD300 painted on 3cylindre gasoline fuel 8 speeds forward 4 in reverse with a hi lo stick and a lever on dash for quick forward reverse what year is it and what modle do you call it thanks for any help you can give
Brandon
03-01-2003 20:42:28
 Re: tractor ID in reply to arthur, 03-01-2003 19:02:55
Arthur,
It sounds like you have a model JD300. This is an industrial version of the green model 1020. If you can recheck and post the serial number on the right side of the transmission (by the footrest), I should be able to tell you more about it, including the year. I see that you posted it, but it doesn't seem correct. It should look something like:
T4W3D 035115 T
Or you could actually have a different model!
Brandon
arthur
03-02-2003 14:05:13
 Re: Re: tractor ID in reply to Brandon, 03-01-2003 20:42:28
brandon i belive my numbers are correct looking at your pictures ther is a diffrence in front of the radiator is the air cleaner the gas tank and some part of the hydrolic system. some one told me it is from the 1970ds.
Brandon
03-02-2003 15:40:18
 Re: Re: Re: tractor ID in reply to arthur , 03-02-2003 14:05:13
The JD300 didn't have the normal "Industrial" look front end, it had a normal ag look. You may have something different than the JD300 I am thinking of, but it was made in the early 1970s. I have some pictures of JD300s at the page below. All are JD300s, except for the first and last picture.
Brandon
arthur
03-03-2003 17:42:59
 Re: Re: Re: Re: tractor ID in reply to Brandon, 03-02-2003 15:40:18
went to the dealer he said itis a J.D.300 industrial about 1975 he sold it to a priveus owner i know him also. will send some photos in a few months after i get repaired. got it to run then some thing went wrongwith the shift dealer told me were to look for a pin that may have broken and to change hydro filters thanks for your help.i look at your web site keep up the good work. art
