CRANK CASE FULL OF FUEL
TOMMY D
03-01-2003 18:00:30
DETROIT 2-53 BEEN WORKING ON THIS PROB IN MY 440 ICD FOR TO LONG, CHANGING FUEL PUMP MADE IT WORSE PULLED VALVE COVER NO OBVIOUS LEAKS CRANKCASE FULL 3 MINUTES RUNNING 3 GAL. FUEL GONE FUEL TO TOP IN MOTOR, RUNNING OUT VALVE COVER BREATHER. WHAT CAN THIS BE? PLEASE HELP HAVE I LOST MY TOY TOM D. WESTERN NEW YORK
bill
03-02-2003 09:44:33
 Re: CRANK CASE FULL OF FUEL in reply to TOMMY D, 03-01-2003 18:00:30
we had 6-71 that did that it was cracked crossover line on injector; Daffin Sales and Service in Omaha could help he has been Detroit man forever ask for Chuck
G Taylor
03-01-2003 18:58:59
Run it with the valve cover off and the leak maybe visible. I'm betting on a failed injector. It can't hurt to change them out for N35's anyways.. You'll need the DD tool for setting the lash. A cracked head will do it too. Any overheating or freezing incidents recently?
TOMMY D
03-02-2003 06:14:44
 Re: Re: CRANK CASE FULL OF FUEL in reply to G Taylor, 03-01-2003 18:58:59
I SEE NOTHING LEAKING UNDER VALVE COVER. MACHINE SEEMS TO RUN GOOD ALTHOUGH SOMETIMES STARTS ON ONE CYLINDER. NO OIL IN COOLANT OR COOLANT IN OIL, WOULD IT RUN WELL WITH FAILED INJECTOR? HOW DO I CHECK FOR CRACKED HEAD? HAVE BEEN SUSPECTING EITHER OF THESE PROBLEMS THANKS FOR YOUR HELP TOM D.
will
03-02-2003 10:25:03
 Re: Re: Re: CRANK CASE FULL OF FUEL in reply to TOMMY D, 03-02-2003 06:14:44
From what you said about it runnig on one cylinder somtimes. I dont know about your climate, but it is normal for a diesel, especially a Detroit to run a little rough when it is cold outside. If your climate is warm, and YOU HAVE NO LEAKS ON YOUR RACK then an injector very well could be dumping. Its opening pressure is too low, so it does not get the proper pressure to mist the fuel but rather drips it. If this was the case the engine would act its worst at idle, as the plunger in the injector would be moving slowly making only minimal pressure, and the blower would not be forcing air at its optimum pressure or volume rendering the engine unable to burn all of the fuel. It would for lack of words flood itself out. The fuel would leak past the rings into the crankcase. If this is the case it is very bad for your engine. It washes your pistons and liners of lubricant rendering their life much, much shorter. Any local diesel parts suplier could check them. If they are bad new N series injectors (35, 40, 45 injectors will all be fine) are not all that expensive especially for just two. I hope you can get out cheap, and the best of luck
G Taylor
03-02-2003 22:43:22
 Re: Re: Re: Re: CRANK CASE FULL OF FUEL in reply to will, 03-02-2003 10:25:03
Can't recomend injectors large rthan 35's ina 440 crawler. The final drives are iffy at stock HP levels and heavy usage. The Deere issue 2-53's with little S35's had no oil cooler or piston cooling spray from the rods.40 or larger injectors can scuff the pistons/sleeves.
TOMMY D.
03-04-2003 06:28:11
 Re: Re: Re: Re: Re: CRANK CASE FULL OF FUEL in reply to G Taylor, 03-02-2003 22:43:22
Mr.T Ihave taken out finals with heavey work logging. Have become a expert at repair. My wife and I can tear a FD down in less then 1 hr. tractor does not need more HP haven"t removed injectors yet for testing need to save machine from boneyard! did you get my mail Tommy D.
G Taylor
03-04-2003 07:18:23
 Re: Re: Re: Re: Re: Re: CRANK CASE FULL OF FUEL in reply to TOMMY D., 03-04-2003 06:28:11
Yes, am following up.Thanks.
TOMMY D
03-02-2003 10:38:53
THANKS WILL, VERY COLD HERE -12 ONE DAY. ONLY START TRACTOR AT AROUND 30. I WILL CHECK INJECTORS DURING THE WEEK. NEED TO GET OUT CHEAP AS UNDER CARRIGE IS TIRED.HAVE HAD TRACTOR 15 YEARS NO MORE MONEY NEEDS TO GO INTO IT, MY USE NOW IS ONLY CASUAL THANKS TOM D. WOULD LIKE TO TRADE FOR WHEELED MACHINE 20 / 35 HP.
G Taylor
03-02-2003 19:22:49
 Re: Re: Re: Re: Re: CRANK CASE FULL OF FUEL in reply to TOMMY D, 03-02-2003 10:38:53
Send an e-mail please to myself, please.
