Need help dateing B
Bapa
03-01-2003 14:25:43
Hi fella's. Just purchased an early styled B but can't read the serial number. Maybe somebody can decifer this info. The PTO shaft is 1 3/8 iches thick, It has a cast frame and cast wheels with removable hubs, It is a hand start, The carberator number is DLTXO, Does not have a water pump, In front of the belt pulley on the main casting, there is a stamped on plate similar to the serial number plate with the number 12. The tractor also has 2 different fuel tanks, and 12 spline axle's. Thanks for any answers you may provide!
Will P
03-01-2003 22:39:06
 Re: Need help dateing B in reply to Bapa, 03-01-2003 14:25:43
1 3/8" started 149700
cast frame was 136662-166999
So it looks like 149700-166999
Or to answer your question,
1944
You should have a pressure cap on your radiator too. Do you?
Will P
Bapa
03-02-2003 19:06:53
 Re: Re: Need help dateing B in reply to Will P, 03-01-2003 22:39:06
Thanks Will P. You were right on the money with your detective work, as my neigbor with a little digging also came to the same conclusion. Thank you much! Bapa
Will P
03-02-2003 20:38:01
 Re: Re: Re: Need help dateing B in reply to Bapa, 03-02-2003 19:06:53
No problem. War tractors are my specialty.
Will P
43A
43B
49G
