70 head on G
Billy
01-05-2004 07:13:28
will a 70 head fit a 1949 G block
buickanddeere
01-05-2004 08:30:30
 Re: 70 head on G in reply to Billy, 01-05-2004 07:13:28
Everybody has already tried that. Only the ultra rare 70 all-fuel head bolts onto the longer G block and bolt pattern. The after market makes G heads with huge ports. And re-po powerblocks with up to 7-1/2' bores and custom bolt patterns.
Billy
01-05-2004 09:29:14
 Re: Re: 70 head on G in reply to buickanddeere, 01-05-2004 08:30:30
OK I wasnt looking for more power just to make tractor run smoother with 2 barl carb.
buickanddeere
01-05-2004 11:42:27
 Re: Re: Re: 70 head on G in reply to Billy , 01-05-2004 09:29:14
Keep the idle speed up to 600+rpm, manifold hot and coolant at 195F. Make certain the carb doesn't leak at the throttle plates and shaft. Compression should be about equal in cylinders. A MSD6 "Blitzburg" ignition system may help with 50 thou a plug gap.
