Implement Studs and Nuts on Rear Axle
DaveH
02-28-2003 07:02:28
When the two cylinders rolled out the factory door were the studs and nuts used for mounting implements to the rear axle installed or were they added later when you bought the implement? On the 50 that I'm working on I only need the ones to mount the 801 hitch to the back. Just wondering which would be more correct - install all the studs or fill the holes with cork.
Thanks, DaveH
poorerbut
02-28-2003 11:53:16
 Re: Implement Studs and Nuts on Rear Axle in reply to DaveH, 02-28-2003 07:02:28
Dave-Most of what I remember was that all but the
top (of the axel) and the front side, had studs
w/nuts (unless you got cultivators with the tractor)-I checked with a couple of 'veteran'
dealers when I did the '70. Put corks in the
holes before you paint.
p.s.-the numbered series had the flat front nuts,
not the round front ones-I found out too late.
pb
Flat front? Round front?
02-28-2003 21:55:23
 Re: Re: Implement Studs and Nuts on Rear Axle in reply to poorerbut, 02-28-2003 11:53:16
What do you mean by "flat front nuts"???
My 1950 B has nuts that are flat on one end, and have a bevel (cone) on the other. The bevel (cone) end fits the mating cone shape of the cultivator parts. Just like the lug nuts on a car or pickup truck, the cone shape indexes and located the rim in place.
poorerbut
03-01-2003 08:58:04
 Re: Re: Re: Implement Studs and Nuts on Rear Axle in reply to Flat front? Round front?, 02-28-2003 21:55:23
I got puzzled on this when Jay & Lee both told
me this. What I had is a mix of round (coned frnt)
and flat (no cone) nuts on the studs. Both of them
said that the coned fronts were from lettered
series to make it easier to put the cultivator
brackets and levers over the 'loop' hole. I also
asked Tom Detweiler and he said the 'flat' no
cones came out with the first numbered series.
I didn't know there was a difference until I
started cleaning them. I'm wondering now if mother
Deere didn't change suppliers and both have the
same part number. Would make a good question for
JR Hobbs or MR T.-
F-I-T
03-01-2003 06:43:44
You lost me there too, Rick.
My parts book shows A 1892 R , Nut, Special for either the "A" or the '70'.
I thought they were all flat on one end and rounded on the other.
Frank-in-Tallahassee
70D // 855
Ralph
02-28-2003 08:39:45
On our '46 A all studs and nut were in place but those used to mount the fenders (triangular set of three each). On a '50 A that I bought from the original owner all were in place but for those on the front(set of 3) and the top (2 sets of 2)of the axle used to mount the fenders.
