4th and 6th gear problems
620guy
02-27-2003 22:31:39
I recently bought a 620 that has transmission troubles. It moves in all the gears except 4th and 6th. You put in one of those gears and put the clutch ahead and nothing happens. The clutch pully turns but the tractor won't move. Where do I start looking to correct the problem? Thanks for the advice.
Clooney
02-28-2003 06:23:27
 Re: 4th and 6th gear problems in reply to 620guy, 02-27-2003 22:31:39
620 guy, it sounds like either your 4th/6th shifter fork is broken, or the 4th/6th shift shaft has a problem, or the 4th/6th gears have sheared a key or otherwise come loose from the trans shafts.
~Probably the place to start is to pull the 4th/6th gear cover from the L/H side of the trans case [behind the rear of the flywheel] & take a look to see if the sliding gear is moving with the shift fork & if so look to see if the gears are slipping on the trans shaft....
