JD 3010 Gas
Wilson
01-04-2004 20:16:04
I bought my first 3010 Gas, the tractor had been sitting outside for sereral years from the previous owner. I have been working a couple of months on the conversion back to gas from propane, replacing and cleaning other items. I fired her up the other day for the first time and the front wheels turn to the right 90 degrees and only turn left about 10 degrees. Is there any easy way to correct this.
Thanks!
Mike M
01-05-2004 09:22:52
 Re: JD 3010 Gas in reply to Wilson, 01-04-2004 20:16:04
I think there is a procedure to bleed the air from that steering system with it running.Check a I&T book if you have one. Mine is not at hand right now.I would try this first. The bleed screw should be somewhere on the top left hand side of the steering valve underneath the dash,it has a nipple to hook a hose to return the fluid back to the resesvior.There is a step by step procedure that needs to be followed.
