How much fluid do i put in fill tube under the sea
Matt B
10-19-2003 16:27:18
How much Hydro. fluid do I put in the trans/diff. case when filling from the hole thats under the seat? Seems like everytime I put some in it just leaks out from every where. If I just put in a gal. or so it seems fine. I just dont want to ruin anything by not putting in enough and not to much as to watch it run all over the floor.
Thanks in Advance.
Matt Model 40 1953.
Wayne in Tn.
10-20-2003 17:47:28
 Re: How much fluid do i put in fill tube under the in reply to Matt B, 10-19-2003 16:27:18
Matt, no problem. Another thought, if yours is leaking bad at the rockshafts, it won't hurt to run it a little low on oil, this will help the leaking while sitting, it will still work fine.
Wayne in Tn.
10-19-2003 16:52:43
Matt, if you are talking about the model 40, that fill cap, under the front side of the seat, is for the hydraulic lift. None of this goes into the transmission or final drives. 10w non-detergent motor oil is reccomended from the factory. It only holds 5 or 6 quarts when completely empty. Open the petcock on the right rear of the lift housing, when oil just begins to drip out,,,it is full. If you think you may have overfilled it, open this petcock and let it run out until it stops. Then you will be at the correct level, also those models are known to leak oil at the rockshaft arms. The fill plug for the transmission is at the right footrest. The fill plugs for the final drives are on the backside. The lower one is to drain, the upper one is for (full)
Matt B
10-20-2003 15:40:59
 Re: Re: How much fluid do i put in fill tube under in reply to Wayne in Tn., 10-19-2003 16:52:43
Thank you so much. I think I have it now. I thought I was putting to much in it. LOL
