G crankshaft...
G-MAN
02-27-2003 07:45:08
Can anyone tell me if there is supposed to be a threaded hole in the flywheel end of a "G" crank? I've seen many with a hole there, and they usually have a bolt and washer in them, with the cranking adapter removed. That's the way mine was. The reason I ask is that I'm sending my crank to the machine shop for work, and I was wondering if that is something that needs to be corrected. It won't be visible with the adapter on there, but I thought I would consider having it filled in if it didn't belong there. Thanks for any info.
Gman
02-27-2003 18:28:36
 Re: G crankshaft... in reply to G-MAN, 02-27-2003 07:45:08
G-man the threaded hole could come in handy sometime if you wanted to attach some sort of pump to the flywheel. I had mine drilled and tapped to install a flywheellocking device,a stroker cann't stand any side motion,due to close tolerances. I'd leave the hole threaded and put the cast cover over the end,I had to purchase one of those suckers boy they're high. Later Gman
Bob Collins
02-27-2003 08:50:55
My GM has two 1/4inch tapped holes with bolts and washers presumably to hold the flywheel on, I'm sure they have been added and I would not trust them to retain that flywheel. I don't think there are supposed to be any holes in that end of the crank except the centering hole which has no threads. The ratchet adapter of course bolts to the flywheel.
Clooney
02-27-2003 08:49:53
G-MAN, the crankshaft wasn't threaded on the flywheel end [at least none that I know of]. You see a lot of G's with that end threaded though. The G had a lot of problems with the flywheels working off the crank when worked so some were threaded & a bolt & washer installed to retain the flywheel on the crankshaft.
~You probably should leave the threaded hole so if your flywheel moves you can retain it with a bolt & washer...
G-MAN
02-27-2003 10:07:33
 Re: Re: G crankshaft... in reply to Clooney, 02-27-2003 08:49:53
I'll probably leave the hole there, as it will be out of sight with the adapter on there, but if the flywheel moves, I'll fix it right, rather than shadetree a bolt on the end. My crank splines are pretty good, so if I find a good flywheel, I hope I won't have that problem.
1955JD's
02-27-2003 08:36:05
Why? would you fill threads? How will crank adapter stay on your tractor.
G-MAN
02-27-2003 10:04:22
 Re: Re: G crankshaft... in reply to 1955JD's, 02-27-2003 08:36:05
The cranking adapater is bolted to the flywheel, not the crankshaft itself.
