JD 2020 3-point
Owl Hollow
02-27-2003 06:07:52
Just bought a JD 2020 but I am wondering what category 3-point hitch it is supposed to have. It is a little too big for my category I stuff, but it doesn't seem to fit category II size stuff either. The 3-point is pretty well worn though. Thanks.
OwlHollow
02-28-2003 04:19:43
 Re: JD 2020 3-point in reply to Owl Hollow, 02-27-2003 06:07:52
The holes in the ball joints on the lift arms are larger than 7/8" for Cat.I, but I can't fit a 1" Cat.II bushing in the hole either. So I was just wanting to know which it is "supposed" to be. I know I can switch the sway blocks for width...and width-wise, the current setup fits a Cat.I. Thanks.
Steve - IN
02-27-2003 10:08:43
Owl Hollow,
I think a 2020 should be Cat I. You may be talking about pin size, which should be 7/8". It's probably capable of handling some CatII implements, but you'd need to change the arms to accept 1 or 1/8" pins, then use collar spacers for the CatI pins.
Steve
John
02-27-2003 07:07:40
By not fit, are you talking about the width between the draft links? If you are that is adjustable with the sway blocks on the rear of the tractor. Maybe you can describe the problem with more detail.
