Carb Model #
John
02-26-2003 14:35:36
Where do you find the carb model #. On the body it says "10 A3". The bottom of the bowl, just underneath the fuel line inlet it reads "DLX 7 A" The "A" is stamped and the "DLX 7" is cast. The "10 A3" is stamped also.
Clooney
02-26-2003 14:55:54
 Re: Carb Model # in reply to John, 02-26-2003 14:35:36
John, the DLTX 7 is probably the bowl number. Check your E-Mail, I sent you a picture showing the place on a DLTX that the number is located...
John
02-26-2003 15:17:31
 Re: Re: Carb Model # in reply to Clooney, 02-26-2003 14:55:54
I also have a carb that reads "10" for number. This looks older and came with the tractor when I got it. I beleive it might be the original and my granddad put a diffrent carb on when he started burning strait gas.
Clooney
02-26-2003 15:19:15
 Re: Re: Re: Carb Model # in reply to John, 02-26-2003 15:17:31
John, the DLTX 10 is an early "B" all-fuel....
John
02-26-2003 15:08:04
Does the model # "67" ring any bells. It was very hard to read.
Clooney
02-26-2003 15:17:42
 Re: Re: Re: Carb Model # in reply to John, 02-26-2003 15:08:04
John, the DLTX 67 is a late gasoline "B". [ding ding]....
John
02-26-2003 15:24:32
 Re: Re: Re: Re: Carb Model # in reply to Clooney, 02-26-2003 15:17:42
Thanks for the help Clooney you are a good man. John
