Idles only
steve
02-26-2003 13:57:02
have a cub that will only idle with choke fully closed, open choke and it dies have 120#compression each cyl. good spark,rebuilt carb. can anyone help me thank you.
twopop
02-26-2003 18:46:32
 Re: idles only in reply to steve, 02-26-2003 13:57:02
I would think that the fuel you are getting is being pulled thru the load jet,which would also make me believe that the two holes,in the carb bowl,that allow fuel to reach the idle jet,are plugged.if you take the bowl off the carb and look in the bowl you should see a hole on each side of the bowl along the ride in the center of the bowl.
