630 p.t.o.
jd520
01-04-2004 18:29:17
i have the pto cover off of a 630 . the clutch pack out because of a broken case.i am getting tranny oil into pto case. where does the seal come out? out of the pto case or do i have to split the tractor behind the axles? i can't pull the driver out of the back of the pto case. thanks in advance !!!!
Clooney
01-04-2004 18:45:21
 Re: 630 p.t.o. in reply to jd520, 01-04-2004 18:29:17
third party image
JD520, unfortunately the axle housing has to come off the tractor [see picture].. Be real careful when removing the hydraulic lines as they break easily & are hard to find replacements.. That rear housing is real top heavy so be careful with that.. Other than the weight & awkwardness it isn't too bad a job..
~While in there make sure the bushing isn't worn as that will allow the shaft to move around...
[email protected]
Clooney (more)
01-04-2004 18:51:02
 Re: Re: 630 p.t.o. in reply to Clooney , 01-04-2004 18:45:21
JD520, I should have added the clutch drum won't come out until the pump gear is removed from the front.. Don't even try or you will ruin the pump..
[email protected]
