4440 - transmission type?
buckaroo
01-04-2004 18:21:51
OK, I give up. How do I tell if I have a powershift or quad range tranny? Mine has two different shift levers, and either 3 forward and 1 reverse or 4 forward and 1 reverse "notches". One of the levers can be moved left and right to change the gear ratio/speed, without pressing in the clutch. Works just fine but it's a little hard to find neutral. thanks.
Ray
01-04-2004 18:32:24
 Re: 4440 - transmission type? in reply to buckaroo, 01-04-2004 18:21:51
You have a quad range,a PS has only one short lever.
buckaroo
01-04-2004 18:36:59
 Re: Re: 4440 - transmission type? in reply to Ray, 01-04-2004 18:32:24
thanks, ray, this forum is like real-time, on-line help. Maybe some day I'll know something to help somebody!
buickanddeere
01-05-2004 08:31:47
 Re: Re: Re: 4440 - transmission type? in reply to buckaroo, 01-04-2004 18:36:59
1-800-522-7448 with a credit card and equipment serial number for cheap manuals fast.
bungo
01-05-2004 11:51:17
 Re: Re: Re: Re: 4440 - transmission type? in reply to buickanddeere, 01-05-2004 08:31:47
you have got a quad range my friend
and the better one of the two the single lever ones i did not like but the twin ones you know excactly where your set to
