44b fan for clooney
ed b
02-25-2003 19:29:10
clooney thanks for the info how would i know if the rubber is ok it appears to be ok just the front of the rubber is a little deterated i took it apart only to replace the felt and the packing ring and would you pry off the retainer to do this the same way that is shown in the repair manaul thanks again ed b
Clooney
02-26-2003 05:50:50
 Re: 44b fan for clooney in reply to ed b, 02-25-2003 19:29:10
Ed, knowing how good the rubber is in that fan hub is a subjective call. Most are starting to dry rot by now. About all you can do is look for deteriorating rubber coming out of the hub & put the fan back on the splined shaft & wobble the blades back & forth & feel for excess blade movement.
~As far as the front bearing retainer goes; before you pry the old one out you better make sure you can get a new one, I'm pretty sure you won't get the old one out by prying on it without damaging it. I usually just remove the fan shaft & tube from the tractor, then pull the fan shaft, then use a long rod with a bent end inserted from the back of the tube & up through the center of the tube to drive the front bearing & retainer out together.
~If you pull the fan tube from the governor make sure to save the rear gasket as that is also a bearing spacing shim & must remain the same thickness for fan gear alignment..... ..
edb
02-26-2003 16:03:46
 Re: Re: 44b fan for clooney in reply to Clooney, 02-26-2003 05:50:50
thanks edb
