Hey there Bryan, well from your question, Im guessing you may have an auxiliary gas pony motor V4 startign engine right????? ?? If its an electrical start or been converted, this is still a good mental exercise to refresh how I used to do it on ponys lol. If so, the small side door pony motor gas tank has to have gas in it, of course. 1. Turn the pony motors rotary gas turn on valve on the dash to open/on (assuming it has one). 2. Switch the dash pony ignition swith to ON. 3. Set the flat lil pony flip START/RUN dash switch to Start. 4. Step on the pony motor electric start switch pedal (down there by left floor plan, looks like a lil pedal) I think the 70 has that versus the 730 push solenoid switch????? ?? 5. Push the lil flat dash CHOKE lever to choke if needed (its by the START/RUN pony throttle) 6. Start the pony and let her run at the start throttle speed a good lil while to warm up and let the ponys exhaust and coolant warm up the big diesel. 7. Now, one of those left side hand pull levers engages the pony to turn the diesel, and the other is a diesle compression release. 8. Set the pony throttle up to the RUN position. 9. FIRST pull back the Compression Release Lever. 10. THEN , pull and hold back the pony engage clutch lever and the big diesel should start to turn, let it turn her a lil bit. 11. THEN, with the clutch lever still back and the diesel turning (have its big right side vertical throttle lever off idle and up/on a bit) RELEASE the Compression Release Lever, and the diesel should crank over a few turns and start. After she starts, release the pony clutch engage lever, set pony throttle back over to START and let her idle to cool a bit, turn off the pony motor gas valve, and finally, turn the pony ignition switch to OFF. 12. When you kill the big diesel, its best to also pull back the compression release lever to reduce strain on the flywheel to crank set. Sorry if I missed something, its been a long time lol and Im not exactly sure you have the dual levers and push pedal switch versus the solenoid and single lever like I think maybe 730 etc or later than 70 had????? ?? Best wishes n God Bless Ya Ol John T Nordhoff in Indiana
