John Deere D Crankcase
Darrel
02-24-2003 19:35:02
Does any one know what the bolt with jam nut on the front bottom of the crankcase is for?Does it need adjusted after removeal?
Jace
02-25-2003 07:25:24
 Re: John Deere D Crankcase in reply to Darrel, 02-24-2003 19:35:02
Darrel I think you're talking about the bolt that keeps the cam follwers' shaft from turning. Unless the shaft was rotated after removal of the bolt, you just need to tighten it down and lock the nut. If it has turned you will need to realign the dimple in the shaft with the bolt hole, so that the bolt can hold the shaft. I doubt if the shaft has turned. Jace
Clooney
02-25-2003 02:24:42
Darrel, if you are taking about the 7/8" stud sticking out of the lower crankcase just right of center it's the bolt/stud for the front axle radius rod pivot. It doesn't need any adjustment but should be sealed to prevent oil leaks.
