JD steel wheels
bill
02-24-2003 11:01:33
I have a rear set of steel wheels for JD, they have a bolted on hub center, a guy offered to buy them, but I dont know what they are worth, I think they are off JD A thanks
easydoesit
02-24-2003 11:06:59
 Re: JD steel wheels in reply to bill, 02-24-2003 11:01:33
Bill,
Are they flats or skeleton? What is the overall diameter of the wheel? How many splines? Wavy center or smooth? Good lugs or worn out? Welds, cracks, rough from rust? Easy
Bill
02-24-2003 11:21:42
 Re: Re: JD steel wheels in reply to easydoesit, 02-24-2003 11:06:59
they are flat spokes, the hub is 12 spline, 2-5/8 dia, the center of wheel is tri shaped with 6 holes for hub to bolt to, lugs are good,no welds some lugs are loose, I didnt measure wheel, stands about like 11-36 rubber thanks
easydoesit
02-25-2003 12:44:48
 Re: Re: Re: JD steel wheels in reply to Bill, 02-24-2003 11:21:42
Bill,
Can you email me at [email protected]?.They sound like styled A's but I can't tell if they are skeleton wheels or flats. Do you have a casting number on them?
ed b
02-24-2003 16:29:06
how many flat spokes and if you look in the back of the hub on the rim there should be a # ed b
