Fan assembly on a 44 b
ed b
02-23-2003 20:22:25
my fan does not look like the manaual or parts book the parts book refers to a fan #ab3300r i would like to know if this is the fan on this tractor it has a splined shaft with rubber around it the pulley that is also on it is a split pulley has anybody rebuilt one of these thanks ed b
Clooney
02-24-2003 05:46:40
 Re: fan assembly on a 44 b in reply to ed b, 02-23-2003 20:22:25
Ed, I can help you a little [at least enough to confuse you more].
~The AB-3300R fan is a replacement fan that is used with the friction clutch system. I think your 44 originally came with the AB-1530R rubber hub fan assembly. [is there a stamped number on your fan/hub?]
~The part I'm not too sure about is exactly when the rubber hub was phased out & the friction drive was brought into production.
~I know the rubber center fan assembly was used as original on the unstyled A's & that fan was carried well into the styled A. The part I haven't ever been able to figure out is exactly how far into the styled era that rubber center fan was used. ~We usually don't get a question like yours, it is usually the other way around in that people have an early A with the friction center fan & want to know if it's original.
~The thing about yours is; most of the rubber center fans have been replaced with friction disk units as the rubber deteriorated in the early fans & the Deere replacement was the later friction center fan.
~If you can ever confirm exactly when the rubber center was discontinued, & the friction disk went into production let me know.
~As far as rebuilding; I doubt you could do it yourself & I don't know of anyplace that does rebuild them. Most people just replace it with the AB-3300R friction center fan asembly & related friction hub parts....
ed b
02-24-2003 16:38:40
 Re: Re: fan assembly on a 44 b in reply to Clooney, 02-24-2003 05:46:40
clooney thanks for the info how would you know if the rubber is ok it appears to be ok just the front is a little deteriorated i took it apart only to replace the felt and the packing ring and would you pry off the retainer to do this the same way thats shown in the repair manaul thanks again ed b
