2640 shifter
Rowalla
02-23-2003 16:51:47
I recently replaced the low/reverse shifter on my 2640 because one of the ears had broken. After putting it back together I could not shift into first/fifth, everything else worked fine. I removed the plate which holds the gear shift levers and could shift into first/fifth. I left it in first and put the plate back on with the right shift in the first gear position. I can drive the tractor now in first gear but can't shift out of first. Does anyone know what is wrong?
