35 A ???s
Larry806
02-23-2003 10:53:58
I'm working on a 35A I've worked on several after 35 but before. This one doesn't have a place for a temp gauge & the oil press. has a rod that pops up not a gauge It has a exturnal oil pump & the push rods are different It that right for a 35? sn 422735 Thanks Larry
36 A
02-23-2003 12:27:59
 Re: 35 A ???s in reply to Larry806, 02-23-2003 10:53:58
Larry806 at ser#424025 the governor case was changed to go along with the new main case ,along with alot of other idems. The oil indicator rod was called the red head.The heat indicator was installed at ser#424851.The oil pump was moved at ser# 424025 also and driven from cam shaft. A new cam with the gear was installed so they may have changed the push rods then.I do know that they are different at ser# 435283 cause i have 2 36 models As each way of that number.36 A
Larry806
02-24-2003 06:39:42
 Re: Re: 35 A ???s in reply to 36 A, 02-23-2003 12:27:59
Thank You that is just what I needed to know Larry
