1952 JD B Timing and Governor Question
Charles
01-04-2004 16:17:05
My 52 JD B has been sputtering out when going up a grade. It started as a minor situation but got increasingly worse. It seems to be getting gas OK and the carburetor has been redone. I checked the timing with a timing light and the marks are right on at idle speed. As RPM's increase the marks widen to about 1 1/4 inch apart..is this normal?? Also, as soon as my JD mechanic gets out of the hospital he will be working on the governor as we know there is a bad bearing inside. Can the governor be causing the engine sputter to the point that it quits on hills??
john
01-04-2004 17:06:19
 Re: 1952 JD B Timing and Governor Question in reply to Charles, 01-04-2004 16:17:05
just a quick thought on the subject leads me to believe that tilting the carb going up hill might mean the float is hanging up on something when its at an angle. i'd like to know what you find out.any chance that the tank outlet is full of trash and stops the flow up somewhat when at an angle. you could just jack it up and turn the drain cock on to watch the veriation in flow when it jacked up and sitting level. a good look into the tank with a flashlight might help. good luck
Charles
01-05-2004 14:43:59
 Re: Re: 1952 JD B Timing and Governor Question in reply to john, 01-04-2004 17:06:19
John, Thanks for your response. I did jack up the front of the tractor and did not seem to be the problem. It seems to happen when there is a load. I know the governor needs work and wondering if the problem could relate to the governor not working properly?
Thanks Charles
