2030 tractors what do you think?
don
02-22-2003 17:49:33
I dont know much about 2030 tractors any info would be good are they as dependable as the 1020 and 2020 were?
G Taylor
02-23-2003 08:35:03
 Re: 2030 tractors what do you think? in reply to don, 02-22-2003 17:49:33
Other than getting old and high hours they are fine tractors. Just make certain the sleeves havn't been cavitate dthrough because the owner never changed the antifreeze. Also adding ordinary gear lube to the combination hydraulic/transmission system will ruin the brake facings. Make certain the trans oil/filter isn't full of silver looking filings.
Terry Clubb
02-22-2003 20:39:43
Don we have used the 1020/ 1520/ and 2020 for lots of hours with out any major problems, traded the 2020 diesel for a 2030 diesel with loader good service also.The 2030 had a little more power than the 2020 just enough to tell when plowing it would go 1 gear higher. The engines were offered in both gas or diesel same as the 2520 all in the 60hp range. good luck Terry Clubb
