720D Plug wires
Hilltopper
01-04-2004 15:33:16
I have been trying to find some copper wires locally. The only thig I can find is a Farmex brand universal wire set. These wire has a keviar inner core with a spiral wound stainless steel conductor. On the wire is written 7 mm stainless steel static suppession mag wire. ARE THEY OK?
Howard
01-04-2004 18:24:25
 Re: 720D Plug wires in reply to Hilltopper, 01-04-2004 15:33:16
Go to your John Deere dealer and ask for part # AA6141R wires. Cut to length.
Hilltopper
01-05-2004 12:35:44
 Re: Re: 720D Plug wires in reply to Howard, 01-04-2004 18:24:25
When I called to order the wires for my pony today the parts lady said aa6141r is for 2 cyl. gas tractors. Glad I had her double check for me.
Howard
01-05-2004 19:03:28
 Re: Re: Re: 720D Plug wires in reply to Hilltopper, 01-05-2004 12:35:44
I know they are for a 2 cyl. gas tractor.They work perfect for pony engines. I should know, I have worked on these engines for 40 yr's.
Hilltopper
01-04-2004 18:55:01
Thanks, I will call Deere and order them. Looks like 6.75 plus shipping. Less than I paid for these.
John T
01-04-2004 17:17:21
Hilltopper, If it were mine, I wouldnt want any wires referred to as "supression". Youre not dealing with the energy and voltage levels those wires were made for and I would try to find copper wire core plug wires with NO suppression or coiling which is inductive etc. They would likely still work, but you dont want to drop any more energy across them than necessary so it gets delivered to the plugs gap.
Good Luck n God Bless
John T
buickanddeere
01-04-2004 16:45:24
Depends on the starting engine coil type. Some have a pointed post that pokes into the ignition wire center core from the cut end to make contact. Other coils have an internal spring terminal that engages a matching tip on the ignition wire. The tip resembles a spark plug top.
Clooney
01-04-2004 16:41:04
Hilltopper, that "static suppression" part bothers me.. Most of those spiral wound plug wires act just like a conventional carbon TVRS plug wire when new & their claim to fame is they don't break down over time like the conventional carbon types do.. Without measuring the resistance & spark output I would be real leery of them...
~Try an old [not the modern yuppie type ] autoparts or hardware store & ask for Packard 440 plug wire.. That Packard 440 is getting hard to find but can't be beat for tractor plug wires..
~Or just call John Billman [610-252-9828] & he will mail you a set of wires or just bulk wire & terminals & you will have them in a few days [good products & priced reasonably]...
[email protected]
John - get performance wi
01-04-2004 15:59:06
Some time back I finally figured out my 720 didn't like the suppression wires that most everyone sells now. Went to NAPA to get a roll of copper and found out that only us old tractor folks want such a mess as that and they no longer had them. Then had a brain fart and went to PepBoys and bought a universal finish them yourself set of high performance copper core wires for a v-8. I ended up with enough wire for 4 JD's and the yellow color matches the wheels! LOL! Oh well, guess that rules out the 'stock' class with alot of clubs. So far no one has complained.
Hal
01-04-2004 15:53:27
I went to tractor supply co. and bought a universal set and made my own wires for the pony and they have been working good for about 3 years now and I use the tractor all the time. good luck
