A John
Family Traditio
02-21-2003 17:15:11
just bought an A and was flushing the radiator cause i took off the water neck and a mouse had gotten down in the block and made a nest..... .already put 3 gallons of antifreeze and 3 gallons of water..... ..how much does it hold?
Lary
02-21-2003 17:42:19
 Re: A John in reply to Family Tradition, 02-21-2003 17:15:11
If that A does't have a water pump ,you should mix your coolant before you put it in the radiator
steve II JD4000
02-21-2003 17:19:14
I just took out the water out of my 44 A, it full up 5 gallon and half. my guess about 8 gallons
yeah cook the mouse.. you may want just full it up with water and let it run out after it cools down, keep using water till it comes clean. dont for get about it so it wont freeze up.
Family Tradition
02-21-2003 17:25:34
 Re: Re: A John in reply to steve II JD4000, 02-21-2003 17:19:14
thanks.....good advice
