Gordon, the only thing anyone can say for "certain" is it depends on if you have a 6 volt coil (ballast needed) or a 12 volt coil (no ballast needed), due to the many reworks and modifications and jury riging Ive seen done over the years lol. My wirign diagrams show the 70 had a 6 volt coil and an external ballast, in which case the answer is YES you need one, assumign you still have an original 6 volt coil. HOWEVER, the diagrams are generic plus modifications or replacements can happen, so I cant 100% guarantee that not being there in person. HOWEVER, if the coils case doesnt say its voltage (many do) I can tell you that many 6 volt coils have a primary (between lil + and - terminals) resistance from 1 to 1.5 ohms while many 12 volt internally ballasted coils range from 2.5 to 3 ohms. DOES YOUR SAY 6 OR 12 VOLTS AND WHATS ITS RESISTANCE MEASURE????? ????? If the coil runs only "warm" once warmed up to the touch with no ballast and the point life is normal, its likely a 12 volt internally ballsted unit and you need no external ballast. However, if the coil gets so hot you can hardly touch it and the points burn up quickly, it may be a 6 volt and you need the ballast. The ignitions primary circuit (coil + any ballast) amperage should be 4 or so less amps to prevent premature point burn up, which means a total of 3 ohms total (coil + any resistor) on a 12 volt system such as you have. Sorry, even though my diagram shows a ballast was used, not beign there and unsure what may have gotten chagnged over the years, I cant say for absolute sure. However, if the coil runs HOT and youre burning up points quickly, you probably need that ballast. Look at your coils case and/or measure its resistance, and if its only 1.5 ohms or so or less, you probably have a 6 volt coil and need the added ballast resistor in series between the ignition switch output and the coil. Let me know, post back or e mail [email protected] your findings. Look out for changes or jury rigging though lol Good Luck n God Bless ya Gordon John T
