Tire gauges
AlbertoV05
02-20-2003 13:02:33
Anybody have a GOOD source for a ag tire gauge that will read in 1 lb. increments and is compatible with calcium chloride?
I've tried the ones from local farm supply stores and even one from Deere. None of them last more than a few months!
Al in Iowa
MIKE HANLEY
02-20-2003 22:53:25
 Re: Tire gauges in reply to AlbertoV05, 02-20-2003 13:02:33
Are you useing it on tires that have fluid?
If so you have to wash it after each use. As it will set up with fluid. Also after washing it after each use I spray the whole works with WD-40 after I wash it. Also if useing on tires that have fluid are you putting the valve stem so it is on the top? I am currantly using a $2.00 gage that I bougth at the quip trip gas station.
AR Roger
02-20-2003 17:21:42
I've got one that I use from 'Snap-On Tools'& it seems to work O.K. Tool # GA315 & it was about $9.00 Canadian. It reads from 5 to 45 in 1 lb increments. It's supposed to be for loaded tires Try this one. Good Luck
