4020 Tires/Wheels choice??
Brad AR
02-19-2003 14:45:32
Simple question, I think.... Purchased a set of 7.5 x 16 rims for the front of my 4020. I know that you can run a tri-rib type tractor (ag) tire on them , can you run the 10,000 type tire also or does it require different rim? Also , which can handle the heavier load? Do alot of heavy front loading and hay handling. Appreciate the help farmers.
barry
02-20-2003 06:20:37
 Re: 4020 Tires/Wheels choice?? in reply to Brad AR, 02-19-2003 14:45:32
hi, if you want the best set up get a rear combine axel , slide in the ends, then use 12.4x24'' tires call me if you want more info. 816 797 5589
scottAR
02-19-2003 18:42:49
I had a 4010 LP with a heavy front blade and I put eight hole hubs from a two wheel drive cotton picker on it with 10.00 X 16 tri rib tires. The tires and rims came from a 966 Farmall. It helped the floation considerably.
