4240 Will not Start with key.
Justin Lewis
01-04-2004 12:31:25
I have an 4240 John Deere that will not start with key. I have checked the netural saftey switch by putting a piece of wire in the connector and still the same thing. The soleniod under the hood clicks with the netural switch hooked up or jumpered. Have shorted across the soleniod under the hood and it will spin over. But not with the key. I Bought a soleniod from Napa yesterday and put it on and it would not even click. Put the old one back on and it would just click. Does it have to be a John Deere Soleniod. I need all the help you guys can give me.
Thanks
Justin
Bob
01-04-2004 14:02:52
 Re: 4240 Will not Start with key. in reply to Justin Lewis, 01-04-2004 12:31:25
Get a new solenoid from Deere. RE-164448, about $15.25.
Brokenwrench
01-04-2004 13:05:12
On the wiring harness going to the firewall from the engine is a seperate 3 guage wire. This supplies power to the cab and starter interlock solenoid. Try wiggling it while someone holds the key to start.When its dirty or corroded at the connections it will supply enough current to energise the guages and click the solenoid but not engage it.
twopop
01-04-2004 13:02:33
you should be able to get a solenoid from napa,however it has to be the right type.you need a solenoid that is internally grounded.however you can use a 4 terminal solenoid by running a ground wire from the extra terminal to the base of the solenoid.
